n1leu
Greetings,
I have found a site called websdr.com where you can SWL without a radio, Its streamed over the web, I use this frequently due to the fact that I am a renter and my landlord is not exactly warm to the idea of me putting up an antenna or three.luckily I can get away with a 2 meter antenna, I regularly use it to drop in and listen to 40 meters and 80 meters, there various virtual recievers to listen to from all over, and if you doze off well the stream will stop if you do not use the controls now and then. it has a passband filter you can adjust, a waterfall display, different modes: AM,FM,SSB,CW, a logbook so you can see and post DX,adjustable bandwith,signal strength plot,audio recording, a widget showing band conditions and more
you can even join as a websdr provider for others to listen from your QTH check it out.
Dave
N1LEU
Dave
N1LEU
