I think the real secret to using an amplifier is placing it right at the antenna and choosing an amount of gain to just make up for feedline loss and maybe just a little more. Worst case if you are feeding multiple receivers just enough gain to overcome splitter losses. That way you don't have to deal with attenuators and everything just works, that is if you chose an amplifier with high enough IP1/IP3 so it never comes close to generating IMD.
The secret to using an amplifier sucessfully are to not have the scanner being feed with a too high signal level. It will first start to de-sense and if the signal are strong enough it will overload and go into intermodulation where you'll hear a lot of frequencies spread over the whole freqeuency band where they actually are not sent over the air, they are produced in the scanner.
Active multicouplers can be sensitive to overload, like Stridsberg, that doesn't like seeing stronger signals on it's input. Stridsberg even did a modification to one guys multicoupler to reduce the input signal as he had nearby transmit towers that ruined the reception in the multicoupler.
If an amplifier doesn't have a variable gain control, then you probably must use an external attenuator after the amplifier to reduce the signal to a safe level. A variable 0-20dB attenuater are perfect for this use.
An example of a good $30 low noise amplifier that can handle fairly large signal levels are this one: Ultra LNA 2GHz Gain>20dB PGA103 ESD Gain Stabilization USB cable PGA-103 NF .5dB | eBay
You have to add cables and connectors to suit your needs and add a $15 variable attenuator like this one, or use fixed attenuators if you know how much to attenuate: ATTENUATOR IEC or F type in line aerial signal reducer 3 6 9 12 15 20dB variable | eBay
A good FM trapfilter are always a good investment, something that doesn't attenuate the VHF airband if you are critical listener to that band.
/Ubbe
