More frequencies for the Motorola HT1000
KC9VZV
If you get a VHF HT1000 you can legally transmit on MURS with them. MURS is like CB except much less used because it is much less known about. Some businesses still use it (including a lot of WalMart locations). UHF, not so much. The HT1000 UHF 450+MHz model won't do you any good to transmit on the ham band either. The ham band is lower, at 420 - 450MHz (ending right where your radio starts). So, the particular radio you got will not do you any good for transmitting. But you can definitely get HT1000s that will transmit in the ham bands or on MURS.
Alright. Thank you. For now, I got the 450-520 band radio, so that won't do me any good, but for the future, that is helpful...
KC9VZV
maxkelley
FN13GF
Actually, Ben, you can put UHF Ham frequencies into the 450-520mhz radios... Just hold down shift in the RSS while typing in the numbers for the frequency (it will show up as punctuation first, but it will then accept it.) I have programmed a few HT1000s in the S split this way, and my MT2000 is an S split that I use on ham frequencies every day with no ill effect.
Just FYI :)
N0BDW
Livingston Co., NY
Just FYI :)
huh... interesting. Thanks for the tip.
