Motorola Antenna mount question
M
mpg0515
Guest
cstockmyer said:
No that's to big..I need a mini UHF to BNC, if there is such an animal.
No, not that I know of anyway.. You can always just cut off that connector (the mini UHF) and place a screw on, or crimp BNC connector on to the RG-58. These connectors work just fine for receiving use. If I were transmitting I would probably use a "true" crimp and soldier connector. The link is for a soldierless screw on one.
http://www.radioshack.com/product/i...+connector&kw=bnc+connector&parentPage=search
cstockmyer
Does a permanent mount make reception better? It's ok with my mag mount, just fuzzy.
RISC777
"Does a permanent mount make reception better? It's ok with my mag mount, just fuzzy."
Not every time, but "most" times, yes.
There's always the same jar of variables. Specific antenna, system(s) monitored, distance, topography, other interference to/of reception.
For example, you have an antenna that designed for 800 MHz reception and has a permanent mount base. You can attach that antenna to a lip/trunk mount. The antenna is not centered above body metal and therefore has a "partial" ground plane. Take the same antenna and attach it to a permanent mount in the center of the top of the vehicle, at a minimum the trunk lid. It then has a "better" ground plane which "should" enable it to perform "better," e.g. receive "better."
But you speak of a mag mount, so it's looking at where on the vehicle are you placing the base (how much ground place is being afforded or provided the antenna)? Is the antenna designed for the ranges / frequencies you're desiring to monitor? Does the antenna need tuning?
Perhaps a partial answer, or not a straight out yes or no, but those are a lot of the things involved to be considered.
cstockmyer
When I get back to Denver, I'll take a Digital pic of where I have it on my exploder. I made an effort to get it as centered as possible, but maybe I am off. At this point I am only listening to DPD, if that helps.
Also has anyone here ever tried a FM Trap on a NMO mount?
