motorola apx 7000 programming
kb0uxv
Minnesota
Hi, what type of encryption are you trying to squirt in? Maybe the radio does not have that algo in the flash, or you are tying to put in more than one key in a non-multikey radio?
motorolahead
Texas
APX7000 CPS - Could not find a radio connected to the USB Port
Wanted to be able to work on my radio with a Windows 7 PC, and after installing the CPS R11 with Driver (that appears in the Network Adapter container) the CPS replies with the error Cannot find a radio connected to the USB port? After reading several dozen posts about it and tried most all of the remedies without results. I don't have a firewall, the computer is not online, allows unsigned drivers, I have enabled only TCPIP IPv4 and IPv6. The adapter reads the radio and produces an IP address 192.168.128.x. There is no added connection (say in the USB container) only the adapter in Network Adapters. Using CPS it will not connect using this adapter. The radio programs successfully on a PC with XP but not on Windows 7. Any direction would be appreciated.
