Motorola APX CPS 31.00.01 CORRUPTION
SCFDCOMM
Just FYI to any and all whom may have migrated to most recent version of APX, there is a Confirmed issue, random codeplug corruption. Motorola Support confirmed the issue and advised there is a forthcoming software release to abate the source code problem. KBA00050213
Use at your own risk, if possible stay a release below until next one comes out.
chrismol1
not surprised. I never use the latest. If you really have to, use the last latest revision of the previous version, both firmware and CPS, of course unless you're forced stuck on the latest
jeepsandradios
East of the Mississippi
Im using 31.00.01 with RM and have not seen an issue. Can you elaborate on what you have seen. I just did updates on 10 portables last week with no issues.
SCFDCOMM
I have also used newest version to modify programming, and do FW updates on quite a few different models of APX, Never an issue until the other day.
Was working on some talkgroup changes on a very large and advanced codeplug and the invalid fields error showed up along with Please Contact Motorola Support.
The usual method of View invalid fields showed nothing wrong. Worked that issue for an hour up to and including restore previous version of CP from the shared drive, same issue happened.
Worked around it with a copy from a week prior, two days later made a change to that CP, and when trying to write to radio same issue happened, Invalid fields (5), Please contact Motorola support.
After speaking to them and creating a case I was made aware of the KB article I referenced above, which they said is an internal KB article and told I could "send them the codeplug for "repair", or wait until the new version is released that resolves the invalid code."
Hope that explains it better. It only happened to three codeplugs so far. They were large, maybe the amount of systems or the size is the underlying trigger?
Only went to newest release of CPS and FW for the Talk Permit Tone which was needed for a special setup. Normally I stay one release behind.
WRTF671
No issues here so far but we're working with a fairly small APX fleet. Most of our infrastructure is Icom now so the APXs tend to be just our personal units. I'll keep my eyes open for issues...
n3obl
ØAES-1024
PA
Some more of motorola fine quality beta testing programs.
jeepsandradios
Ive been using 31 for a bit now and many of my code plugs are over 100 zones and have yet to have this issue. I just upgraded RM to 31 so try testing there.
KelzClive
NJ
I have been using 30 but was forced to use 31 for a warranty repaired radio. No issues to report, yet. I guess it wouldn't hurt to keep backups of your codeplugs.
RodStrong
West
I got a radio back from depot and it wants to see 31.0. I was using 29.0 so I went to MyView to update. However, the newest I see on MyView is 30.0. I suppose it could be an issue on my end, but does anyone know if maybe they removed 31.0 off the site until they can fix it? I tried to call today but I think they are all closed for Veteran's Day. Thanks.
