Motorola APX Software Refresh Error
firephoto29
WRVL541
Northern Nevada
Hey! I am attempting to upgrade my APX7000 software from R14 to R27, although once CPS reads my radio info it gives me the following error code:
Retrieving the COM class factory for component with CLSID {143DF7EB-75CC-4709-B70A-56097EEDED22} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
I understand this issue from Windows as all the research I have done on it only gives me solutions for Windows software.
Does anyone know how to fix this for APX CPS or have any information to help me out? I am pretty much clueless on this
Thank you!
Echo4Thirty
Colorado Springs, CO
I would try this too, read the radio and without making any changes, write it back., This will update the codeplug version. Once the radio reboots, try firmware again.
Failing that, might be time to uninstall, reboot and reinstall CPS
jeepsandradios
East of the Mississippi
n3obl
ØAES-1056
PA
You mentioned r27 in one thread and r28. You need to use the same cps as firmware version as a minimum when firmware updating.
Unless you have a specific need for a newer firmware might be advised to stick to 21 or 23 firmware. Later versions are buggy.
