Motorola CDM Programming Error
dixie729
Daviess Co., KY
Failed to write radio due to "invalid fields"
I select the errors, "can not be found" box appears.
Invalid Field # 1
rdkRecRefIndex_3733_3734
Invalid Field # 2
rdkRecRefIndex_3728_3729
Anyone know what these errors are and why it won't allow me to view or fix them?
Kevin
Sent from my XT1097 using Tapatalk
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Invalid Field # 1
Invalid Field # 2
Kevin
Send me your codeplug and I will see if I can find the problem. I think you already have my email.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
What did you change since the last time the radio was read or written to? If it was only a few things, then you will have to slowly go through each portion of the codeplugs. If it was many things, then you may have to start over and only make 1 change at a time, then write the radio. For me, the errors always seemed to happen when I deleted items OR when adding new items. Then, it was typically in the scan lists or some default that got added when I added a new channel. TT
dixie729
Daviess Co., KY
I was doing some Re-Programming, so it would not allow me to save the code plug. But just for future reference you can PM it to me if you like.
dixie729
Daviess Co., KY
I edited some channels, deleted MDC system, edited the scan list and changed the audio alert levels to "fixed"
That's about it.
TampaTyron
Phoenix, AZ
One you deleted the MDC system, did you check every channel in the radio to ensure there was no reference to this deleted system in the MDC tab? I wonder if you missed 2 of them....TT
dixie729
Daviess Co., KY
Fixed it. It was the MDC system I deleted. Made another system. Read just fine. Thanks
