Motorola CDM1250 Programming Problems
TimmayCG
Milwaukee, WI
I'm currently having some trouble programming CDM1250s. When I try to read the radio, I'm getting an error saying to ensure power is turned on for the radio and RIB. I've verified the RIB is working with a Astro Spectra, however no luck with (2) CDM1250s...
Any suggestions?
DPapay
Morris County, N.J.
If you can program the spectra, then check the cable from rib to radio. If the cdm is a dual head, make sure you disconnect the dual head interface box, and reprogram from one head only. You could damage stuff if you try to go thru dual heads.
RKG
Boston, MA
Two other possible ideas:
1) Be sure the 9V in your RIB is fresh; CDM radios seem to be sensitive to this.
2) Be sure your cable is for a CDM and not an MCS2000; they look the same but are pinned differently.
ryan81986
Also make sure that there are no damaged or dirty pins in the "outlet" for the CDM mic plug.
TimmayCG
Milwaukee, WI
I figured it out, I'm using a AARKN4081B which doesn't require a RIB... Just had to find a parallel to serial adaptor
Thanks to everyone who responded!
