Motorola CPS Programming Error
gip127
Member?
New Jersey
I recently moved from my desktop computer to a laptop computer to program my radios. I tried transferring my Motorola CPS by bringing all of the files over on a flash drive, because I cannot find my disc. The software works no problem on the desktop, and gives me the error code "Unknown Radio Component not registered" when I try to launch the software on the laptop. I ran the registerCFSwrapper file to try and register it, that goes through no problem. Any and all help is greatly appreciated.
- Greg
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
- Greg
You can't just move the files. You have to install each CPS from either the disc, or if you have copied the disc to a folder, you can copy that folder to the new PC and then do the install.
When I receive a new version of a CPS, I copy it to at least one flash drive and to a unique folder on each computer. That way I can install it no matter what the situation.
gip127
Member?
New Jersey
Guess I am all out of luck then... Def do not have the discs....
n5ims
Your CPS is legal right? If so, you should be able to contact Motorola and get access to download a new copy directly from them.
Kb2Jpd
New York City, NY
And there are plenty of "other " copies being sold on the Internet, pristine and modified.
