XPR Motorola DM2600 (CM300D)
Trooper_Dean
Hello, I have a fellow ham's DM2600 on the bench. Radio can't be readed, CPS doesn't recognize it. It gives the device descriptor request failed (43). I tried with his homemade cable and also with two of mines ( homemade and OEM). He states that he had problems with the ignition sense turned on so he gave a direct 12v to the wrong pins ( between 13 and 16), after that he felt the smell of smoke and now radio can't be readed. What can it be?I have a guy telling me that I also need to run + to some other pin to get radio in the programming mode. Now I have it connected to pin 10 and it only turns on.
K2NEC
5F6
The radio has no "programming mode"
Does it even power?
K2NEC
5F6
Do you know which pin was put power to specifically? Pin 14 is a programming pin, which would be less than ideal to put 12v to that
Trooper_Dean
OK so it's either a problem with the port on the front or your programming cable
I tried with 3 programming cables and nothing. They work fine on others. It's probably the front port but what can the issue be? Could I maybe program it with the back port programming cable?
K2NEC
5F6
I re-read your post and edited my response. If he put 12v to pin 14 (between 12 and 16) it could have damaged or destroyed the programming capability of radio. Try a rear cable but I wouldn't hold my breath
Trooper_Dean
He probably did. It was somewhere near that one. Will probably be $$$.
Trooper_Dean
Did anyone have similar situation? Or if somebody maybe knows which component maybe got fried?
a417
TBH, it's not on my bench. If you have it apart you can go looking. If you have a thermal camera you can look for hotspots with power applied carefully, or you can look at components with a magnifying glass and try to see skidmarks, etc... A schematic would help, as well.
Hard to do remotely.
Trooper_Dean
Will do that. I will keep you updated. Thanks a lot!
