Motorola Minitor IV
codymw623
Ebensburg PA
Does anyone know what the latest Firmware is for Motorola Minitor IV UHF. Is there updated firware out there for either the IV or V.
Cody
codymw623
Ebensburg PA
Also are the Minitor IV narrowbanded capable. For some reason i seem to be having an issue with the pager receiving transmissions when i have it selected to monitor. All the transmissions are scratchy and cut in and out the whole time. Is there a way to fix this. I looked at a Minitor V programming. Now i know there two different pagers but under the General Tab where it says Mhz it shows a 45. Now with my Minitor IV under the General Tab it shows a 21.4 Mhz. What is that and is that the reason why its cutting transmissions off.
druhe
Southwest Pa
The Minitor IV is NOT narrowband compatible. It almost sounds like your squelch setting is to high.
xxdanielt3
PA
Minitor I, II, III, and IV all will work after the set narrow banding date. Now the transmissions may come in scratchy or scattered. A Minitor V is the only pager capable of narrowband.
With that being said is this problem all of a sudden or has it been happening for awhile?
