Motorola NAS tips?
Omie09
I have an XTS5000, and I recently set up NAS. It doesn’t affiliate at all. However, I am having trouble hearing transmissions and the radio is missing them. I’m unsure what the issue is but I feel like I may have possibly messed up the band plan. Any tips to stop missing transmission? (Monitoring Starcom21)
Omie09
ima ask the obvious.... encrypted? or is the channel you are monitoring mainly TDMA but goes to FDMA when theres a phase one radio on it.....
The talkgroup is FDMA, “D mode”, and I can only hear some of the activity on it. I don’t think range is an issue because the repeater is only 2 miles away.
K2NEC
NA
Id check your band plan. That's usually the first thing when people say it doesn't work.
Also check your scan list assignments, those too are easy to mess up.
Omie09
Unless the system information came from the system admin/owner, you don't really know. Crowd sourced information doesn't have access to the TG/MG profiles on the system side, only the ones who operate it can confirm how a given TG is configured.
Well, I really don’t think this is the issue, as I used to do conventional scanning, where you put all the site frequencies into a scan list, and I was able to hear the talk group every time. I did that until now, I’ve finally got my hands on what I needed to do “real” NAS.
