Motorola NAS tips?
Omie09
I have an XTS5000, and I recently set up NAS. It doesn’t affiliate at all. However, I am having trouble hearing transmissions and the radio is missing them. I’m unsure what the issue is but I feel like I may have possibly messed up the band plan. Any tips to stop missing transmission? (Monitoring Starcom21)
Omie09
ima ask the obvious.... encrypted? or is the channel you are monitoring mainly TDMA but goes to FDMA when theres a phase one radio on it.....
The talkgroup is FDMA, “D mode”, and I can only hear some of the activity on it. I don’t think range is an issue because the repeater is only 2 miles away.
K2NEC
5F6
Id check your band plan. That's usually the first thing when people say it doesn't work.
Also check your scan list assignments, those too are easy to mess up.
Omie09
It can also be a DDM talk group- when an FDMA subscriber registers, you'll hear traffic. When it de-registers, the TG reverts to TDMA and your old radio sits silent. Depends on the system.
Maybe, but wouldn’t it say TDMA capable talk group then?
MTS2000des
5B2_BEE00 Czar
Unless the system information came from the system admin/owner, you don't really know. Crowd sourced information doesn't have access to the TG/MG profiles on the system side, only the ones who operate it can confirm how a given TG is configured.
Omie09
Well, I really don’t think this is the issue, as I used to do conventional scanning, where you put all the site frequencies into a scan list, and I was able to hear the talk group every time. I did that until now, I’ve finally got my hands on what I needed to do “real” NAS.
Omie09
Problem solved. Changed trunking system search time to 255 and digital modulator to CQPSK. However, encountering a new issue. When receiving specific talkgroups, Fail 001 will appear, but all other talkgroups and trunking systems work perfectly. Does this mean there is something wrong with tuning, programming error or simply p25 phase 2 in use?
FFPM571
Nashvillle
It wont be long before that radio is useless as that area is going to be moving soon to all Phase II as the older XTS's are phased out
Omie09
I am aware of that. Are you also trying to say that the fail 001 is due to phase 2 activity on the talkgroup?
Omie09
Unless you know exactly what you are doing with NAS and do it properly it is not a good idea....
I have been perfectly with talk groups in Will county. This issue is fail 001 while trying to monitor Starcom in Dupage county. As far as I know I have set up the trunking system and scan the same way and I was asking for a solution or answer.
