Motorola PMMN4097 Bluetooth Gateway Mic XTL Compatibility
APX6k
Does anyone happen to know if the Motorola PMMN4097 Bluetooth Gateway Mic will work with an XTL2500 dash mount? It's officially marketed for the APX series, but I've seen a few sellers advertise XTL compatibility as well. Hoping since both product lines utilize the same GCAI connector that I am in luck, but thought it prudent to ask before shelling out ~ $500 for the gateway / RSM combo. Thanks in advance!
APX6k
Absolutely. I am using on on an XTL5000 dash mount in my house and paired with my bluetooth RSM, pretty much "whole house" coverage.
Awesome! Thank you so much for taking the time to reply. That is actually EXACTLY what I am looking to do. I have an APX8000, but an HT doesn't play well with the steep pitched metal roof I have when I'm upstairs, so I am going this route to extend my XTL2500's coverage throughout my home.
MTS2000des
5B2_BEE00 Czar
This is how I use my VHF ham repeater from home. Portable coverage is non-existent. No problem for my XTL5K connected to a Diamond X-300 40 feet above ground. The mission critical RSM is class 3 bluetooth and works well in this application.
y85csm
Electron Wrangler
Wrong side of the tracks
XTL radios require firmware newer than R12 for the Gateway Mic to work.
The Gateway mic doesn't work on the APX Vehicular Adapter, either.
APX6k
This is disappointing news... My XTL2500 firmware is at R09, and I am well aware it's NLA from Motorola :( Oh well, it may finally be time to upgrade to an APX4500 or possibly a 6500 for my home setup. I appreciate the replies!
