Motorola programming software programs all failed HELP ?
Beeperguy
I have about 15 Motorola PPS software programs installed in a laptop and have for ohhh 35 years now and it’s worked great. Until I tried to install the time port disk and failed at installing it which is fine but now every program now says it can’t find the port or read the pager. I have tried all ports and changed the sensor to all 3 Choices. Nothing seems to work now and it’s been way to long and I have no idea What happened. Please help.
ElroyJetson
It's almost a miracle that a 35 year old laptop was even still running. Now tell me, why would you dare to try to change a fragile 35 year old system in ANY WAY, with the possibility being that you'll break it?
DON'T MESS WITH SUCCESS.
FKimble
Newnan, GA
More info would help. I assume you are exaggerating with the 35 year old part. What is the OS? what is the speed? how much memory? Disk size? Free disk space?
Frank
MTS2000des
5B2_BEE00 Czar
Most PPS (pager programming software) is MS-DOS based, with the later model like Minitor 5/6/7 being Windows based, so he'll most likely need a DOS capable PC with a true serial port to support legacy pagers and newer stuff. A Dell Latitude D630 is a good cheap versatile machine to get. Usually can be had for less than a hundred bucks, can run Windows 7/10 and can be booted to DOS off CD or thumb drive. I have one and have a small 200MB FAT-16 partition on the HDD for running legacy RSS. Boot to MS-DOS with a CD, the only partition it will see is the FAT-16, where old legacy RSS lives forever.
