Motorola RNET 450
Project25_MASTR
Millennial Graying OBT Guy
Texas
I understand these things are about as old as I am. I also understand that they are crystal controlled telemetry radios. However for the guys that still may remember these, aside from getting the crystals, can I take two of these and make a simple repeater fairly easily? I know it may not be practical but I'm just kinda curious.
com501
These are excellent radios, have pretty much everything you need already ported out including flat audio and PTT. Earliest version were based on the P10/P50 (1w & 5w) portables, and a later version was synthesized and used a GP300 chassis. International Crystal should be a source if you have the crystal version.
Project25_MASTR
Texas
Cool that's the bulk of what I needed to know. Mine are the crystal controlled versions (5W I believe). I can't find the service manual anywhere. I'm probably safe assuming the radio can not run full duplex so I'll have to use the two I have, one for RX and one for TX.
Any tune up on them? I think one is close to the GMRS repeater inputs at 467.3 MHz and the other is in 464 MHz range, don't know if that 2 MHz is too far of a stretch without realignment.
com501
TX and RX will need alignment. Manuals should be out there if someone has scanned one. They were produced before any were ever placed on line.
cmjonesinc
I can't find a download but I can find several places to buy the manual. I assume it's service as opposed to operating as I can't find but one. But the number I came up with is Motorola 6880901Z35. Hope that helps some.
