Motorola XTL2500 Issue after firmware upgrade
MatthiasTHM
Wisconsin
Hello, everyone!
I have run into an issue after upgrading the firmware on a Motorola XTL2500 from R08 to R20. After the firmware was upgraded, the radio has been stuck on the “Maintenance Mode: Remote Control”. The radio is a dash mount and I don’t know what happened.
What should I do?
n3obl
Ø
PA
AN or BN radio?
There is no an or bn in astro25 mobile radios.
As to the OP the radio is currently bricked. Its a common problem with the flashing process for astro25 gear vs apx.
Using serial cables you may be able to undo the bricking.
MatthiasTHM
Wisconsin
I was using a rear accessory cable, but that didn’t help it.
MatthiasTHM
Wisconsin
The issue was resolved. I used a regular speaker and ignition sense cable for the rear as programmed, and use the car’s power to keep it up. I still used the front accessory port cable. It is successfully upgraded and functional now.
nokones
Sun City West, AZ
W series is not supported on xtl2500 radios. Unless it was flashed as a 5000 mobile.
I know that and that is beside the point I was going to offer up on how to unbrick the radio if the radio is not communicating with the controlhead. I know how to unbrick a XTL radio if you get the FL 1/90 error. It has everything to do with the "W" Series controlhead.
MatthiasTHM
Wisconsin
I personally like the W series control head as well and use them for almost all my stuff because of the optional siren controller and extended DEK.
