Motorola XTL5000 High Power W3
kenneykirk
Springfield, IL
After months of searching and many WTB ads, I by the grace of God, have acquired 2 W3 TIBs for High Power radios. The radio previously had an O series TIB with an 05 head. I changed the head to W3 in the CPS so now I have to make this work. I'm testing with DB25 breakout connector and a W3 HHCH. I connected a B+ line to pin 3 of breakout DB25 connector. I can't seem to get the radio to power on. A look at the schematic shows both DB25F connectors on the W3 are connected to the same lines. When I tested for continuity to pin 3 on control head DB25F I get nothing. I read something about changing a jumper in this senerio but, in what configuration then would this work without changing the jumper?
DMS11B
Closet Nerd
Cali
Did you run sync control head?
WRZT722
Do you know what the part number is or where to find those w series high power tibs?
