/motorola XTS-3000 VHF model II
n2jve
Niverville, New York
Hi All and thanks for reading.
I recently moved to another county and I wanted to add a second scan list to the XTS-3000. I know that the frequencies that want on the second scan list i set for number 2 but how do i control switching between scan list 1 and 2?? Thanks in advance for your response back.
Mike N2JVE
Asunakiyori
Lurker
Hiding in a Shed somewhere
This is the way I do it. I have one zone set for 1 list. I have a 2nd zone set to the other list. so I'm basically zone hopping I don't believe there is a built in "I wanna us this list and not this one right now" function other than adding an additional zone assigned to that list with the scan list.. if that makes sense my XTS has 6 scan lists
nokones
Sun City West, AZ
Depending on the number of Zones configured, you can program the ABC switch for selecting the Zones easily. Depending on if you intend to use the same Tx/Rx channels for the second scan list you will need to create another conventional personality for each Tx/Rx channel pair to scan the second list and of course a second scan list.
KE4ZNR
Radio Geek
Professional grade radios are not scanners so you don't "select scan lists". You select zones and whichever scan lists are slaved/attached to those zones/channels are what is scanned. This is why professional grade radios usually make subpar scanners. Scanning is an afterthought in these radios (though it has improved somewhat in recent generations).
