Motorola Xts 3000
vacaville707
Okay so I have issue it's Motorola xts 3000 model III it suppose to be programmed to receive on certin channels only and transmit on certin ones. The problem goes away if I unscrew antenna. The problem is on a certin freq the led indicator light will not stop flashing even when they aren't transmitting I don't keep it on that channel much . When scan is mode is on it goes away but constantly scans picks up everything when scan is turned off only one freq acts up I can here them transmit well but then after a few mins I will dispatcher say open mic can someone look at code plug if I let them no the freq that is acting up so they can look at it seems only just be one that is acting up . Please contact me back leave email address for better response thank you .
rescue161
KE4FHH
Hubert, NC
Did you press the monitor button on the side to determine if someone/something is actually transmitting on the frequency? If you have PL/DCS on the receive side, you won't hear anything, you'll just see the red LED on top.
This also could be a secure setting. If someone else on the system is transmitting in secure mode and your radio is set to not unmute on an incorrect code, then you'll get the same symptom.
vacaville707
County fire 1 doesn't use secure mode *no I didn't press the monitor button . When light is flashing there is no transmission being made on radio reference live audio feed either. When I unscrew antenna it stops blinking then resumes . I can here then transmit on it though but after they transmit on it I will here county fire 1 check for open mic I notice when I turned off that channel it went away and they no longer said it on the live audio feed either every time I go that channel it does that . Can you look at the code plug if you no what that is for that specific freq if I give you that information can you look at it? The led light just flashes non stop only for that one even when no transmission being made. *
rescue161
KE4FHH
Hubert, NC
Yes, I can look at the codeplug, but I'm still thinking that the frequency itself is what is having the issue.
vacaville707
Maybe I am not sure because county fire one seems work fine on live audio feed on radio reference . Send me your email I can send you the code plug with the freq that's acting up I was thinking about taking pl off changing it to CSQ .
