Hello all, I recently got a Motorola XTS2500 and the correct programming cable. I got the ASTRO 25 software and got it to read the radio and am able to change some settings, specifically only radio buttons and knobs as well as certain conventional information. I am not able to change any trunking information, which is the reason I got the radio (to use as a non-affiliate scanner). It is a 7/800 and currently has a trunking system programmed in, but I am unable to change any settings in that system as well as unable to add another system to override. It also appears that I can change essentially nothing on the radio. Any help in this matter would be greatly appreciated.
P.S. If this tidbit of info will help I got it from Haloid Radios and believe I got a good deal on it, but that may not be the case.
