Correct, in trunking mode the radio HAS to register with the system AND affiliate before it will unmute.
Is there any way around that?Correct, in trunking mode the radio HAS to register with the system AND affiliate before it will unmute.
Interesting. Where can I find this guide?Yes, there is a proper way to set up a motorola radio to do what you want without any TX at all. I think someone (Elroy?) wrote a guide on how to do it.
What's this all about?I would be surprised if meeting the admin is just only a talk with both parties present involved in it. Consider selves very lucky if so. If a cat has 9 lives I'd say they were all spent in that slap on hand talk.
You have something wrong somewhere. Even if you leave the offset alone and your radio is parked on a conventional channel, the radio will not affiliate to the system.The problem that I'm running into is that when the offset is changed so that there's no way for it to connect to the control tower, there's no audio on the channel I have slaved to a tgrp. As if the radio MUST transmit data and connect to the control tower to receive any audio fron the tgrp even though the tgrp is slaved to a conv channel scan list. And I don't want it to affiliate.
Sounds like the only way to use these without affiliating is to set up receive only conventional scan channels that scan the voice channels and NOT utilize the trunking at all.
After reading all this i am more confused, lol. Whether it can, will, won't just scan and not affiliate and all. Way above my pay grade. It appears that sometimes people have questions and some folks bash them because of it. I have learned alot from these forums, how else will I or anyone else learn unless questions are asked?
Be safe
It's all really confusing. I can program my scanner and that's about it.Anything your're referring to Ask away. Don't be confused. In my opinion, most of bashing is to scare away those, if theres a whiff that specifically those who seem to not have the basics, who show to not understand the very real repercussions of screwing up NAS, because of obvious reasons of affiliating if you screw up the programming such as putting the trunked talkgroups first instead of conventional in the zone, if one has underlying knowledge of programming and more importantly the drive to learn and succeed properly without error, its not difficult, which was the basis for the original NAS instructions, it was not a complete guide for beginners whose touched a radio the first time the day before
