MOTOTRBO and APX radios automatically transmit when plugged into the computer.
hst111
My MOTOTRBO and APX radios continue to send signals every time I plug them into my computer. And the computer will become inaccessible to the Internet. I want to solve it, but I reinstalled CPS and Driver to no avail. Please help, thank you.
RRR
OFFLINE
USA
Are you absolutely sure you’re using the correct cable?
hst111
YES. For R7 is PMKN4265A. Use the same cable works well in other computer.
Final I Reset all of my computer internet setting and it comes good.. No more transmit.
Firebuff880
Boynton Beach, FL
So this is a somewhat known feature.
When you plug the cable into the Workstation you get a device generated with an IP Address. The default is 192.168.1.1 and this just happens to be the default gateway IP of many SOHO / Retail networking products.
So when you connect, all sorts of data goes out the Radio Connection instead of the Network card to your normal gateway. Also, probably 192.168.1.1 Look a the routing table in your PC, netstat -rn in an elevated authority command window.
