ZihanIT
there is one mototrbo system near my house , It's display DMR (MOT) in DSD+ ,I guess this system is a capacity plus , in this system they have ARS RAS , But It's ok because i have the port of ARS , service IP of ARS and the RAS key ,but when i turn on my radio ,it display that I'm out of range ,I can hear the voice form my radio(XPR 6550) but i can't TX.
The code up there ,ID =57037 are login in (ARS) ,and the code up there got some LRRP fix with hope someone can hlep me decoding that
down-this-line it's TX ARS(form my device),the channel I Tx is a DMR normal channel,It's not trunk mode。I don't know if there is diffrent betwen Cap+ ARS and normal channel ARS。hope there is someone can help me out。
down-this -line It's picture of DSD+ event
it
could guys tell me when you find something? thanks to you
Code:
Activity update: Slot1=No Activity Slot2=Indiv Data
-DMR slot2 BS DATA DCC=4 CSBK [LB=1 CSBKO=41 (?) FID=10 v16=00DF id1=2031872 id2=16515072]
29 10 00DF 1F0100 FC0000
101010010001000000000000110111110001111100000001000000001111110000000000000000001101100111110001
-DMR slot1 BS DATA DCC=4 Idle
-DMR slot2 BS DATA DCC=4 Data Header DPF=[2:UcData] Tgt=2010000 Src=57079 Conf=0 SAP=[4:IP Data] Blocks=5 Pad=7 Last=0 Seq=0
-DMR slot2 BS DATA DCC=4 Rate 1/2 Data 45 00 00 31 08 CF 00 00 40 11 CE 47 E..1....@..G
-DMR slot2 BS DATA DCC=4 Rate 1/2 Data 0C 00 DE F7 0D 1E AB 90 0F A1 0F A1 ............
-DMR slot2 BS DATA DCC=4 Rate 1/2 Data 00 1D 83 4A 0D 13 22 03 00 DE F7 66 ...J.."....f
-DMR slot1 BS DATA DCC=4 CSBK ECC/RAS
-DMR slot2 BS DATA DCC=4 Rate 1/2 Data 2B 91 30 D4 51 5A AE 0F 6C 00 5E 56 +.0.QZ..l.^V
-DMR slot1 BS DATA DCC=4 Data Header DPF=[2:UcData] Tgt=2010000 Src=57036 Conf=0 SAP=[4:IP Data] Blocks=3 Pad=1 Last=0 Seq=0
-DMR slot2 BS DATA DCC=4 Rate 1/2 Data 6C l LRRP; Tgt=2010000 Src=57079 30.63315 114.40436 1.6mph 216deg
-DMR slot1 BS DATA DCC=4 Rate 1/2 Data 45 01 00 1F 01 04 00 00 40 11 D6 4E E.......@..N
-DMR slot2 BS DATA DCC=4 Rate 1/2 Data 6C 00 00 00 00 00 00 00 55 94 B6 8C l.......U...
-DMR slot1 BS DATA DCC=4 Rate 1/2 Data 0C 00 DE CC 0D 1E AB 90 0F A5 0F A5 ............
Activity update: Slot1=Indiv Data Slot2=Indiv Data
-DMR slot2 BS DATA DCC=4 CSBK [LB=1 CSBKO=41 (?) FID=10 v16=0000 id1=512 id2=16515072]
29 10 0000 000200 FC0000
101010010001000000000000000000000000000000000010000000001111110000000000000000000010001100100011
-DMR slot1 BS DATA DCC=4 Rate 1/2 Data 00 0B 0C 12 00 01 31 ......1 ARS; Tgt=2010000 Src=57036
-DMR slot2 BS DATA DCC=4 Data Header DPF=[2:UcData] Tgt=2010000 Src=57119 Conf=0 SAP=[4:IP Data] Blocks=5 Pad=7 Last=0 Seq=0
-DMR slot2 BS DATA DCC=4 Rate 1/2 Data 45 00 00 31 01 54 00 00 40 11 D5 9A E..1.T..@...
-DMR slot2 BS DATA DCC=4 Rate 1/2 Data 0C 00 DF 1F 0D 1E AB 90 0F A1 0F A1 ............
-DMR slot2 BS DATA DCC=4 Rate 1/2 Data 00 1D 82 AB 0D 13 22 03 00 DF 1F 66 ......"....f
-DMR slot2 BS DATA DCC=4 Rate 1/2 Data 2B 90 E6 33 51 5A BB 27 6C 00 77 56 +..3QZ.'l.wV
-DMR slot2 BS DATA DCC=4 Rate 1/2 Data 69 i LRRP; Tgt=2010000 Src=57119 30.63235 114.40465 2.0mph 210deg
-DMR slot2 BS DATA DCC=4 Rate 1/2 Data 69 00 00 00 00 00 00 00 8C 6E 22 FC i........n".
-DMR slot2 BS DATA DCC=4 CSBK [LB=1 CSBKO=41 (?) FID=10 v16=0000 id1=768 id2=16515072]
Code:
-DMR MS DATA DCC=1 Data Header DPF=[3:ConfData] Tgt=2010000 Src=57204 Conf=1 SAP=[4:IP Data] Blocks=3 Pad=4 Last=1 Seq=0 S=0 N(S)=5
-DMR MS DATA DCC=1 Rate 3/4 Data 45 01 00 28 00 0D 00 00 40 11 D6 94 0C 00 DF 74 E..(....@......t
-DMR MS DATA DCC=1 Rate 3/4 Data 0D 1E AB 90 0F A5 0F A5 00 14 DF 92 00 0A F0 20 ...............
-DMR MS DATA DCC=1 Rate 3/4 Data 05 35 37 32 30 34 00 00 .57204.. ARS; Tgt=2010000 Src=57204
Sync: no sync
Sync:+DMR
-DMR MS DATA DCC=1 CSBK ERR8 ECC FAIL
-DMR MS DATA DCC=1 CSBK ECC/RAS
it
