Mototrbo Wireless RSM compatibility
Floridarailfanning
East Tennessee
I've got some questions about the WRSM RLN6562(a). I have been looking at buying one of these for a long time and think I have finally decided to get one but had a few compatibility questions. Is Data Services via Bluetooth HKVN4249 required to use this device with an XPR7550? I know some stuff refuses to pair without this option installed.
Also, will this RSM pair to XPR5000e radios directly, or is the Long-range Bluetooth gateway required? I get the point of having the Bluetooth gateway is to increase the range to 328ft, but I am curious if it could be used in close proximity without it.
n3obl
Ø
PA
You do not need data services to pair the mic to the radio. That’s for other uses of Bluetooth.
Not sure if compatible with mobile. I have one and can try it out.
Floridarailfanning
East Tennessee
Thanks for the info. Having seen the "Purchase Required" message before when pairing stuff I wasn't sure if this would be another cash-grab by /\/\. I would appreciate it if you could test it on the mobile as well. I wanted to ensure there wouldn't be any surprises if I paid $189 for this just to find out it wouldn't pair!
Tech21
Order the radio with bluetooth capability from the factory. Bluetooth then has to be enabled in the codeplug.
