Mounting a CB antenna on a modern hatchback without drilling?
KK4HBW
Any idea what could be wrong inside of it that I may be able to swiftly fix? Or is it a nightmare to deal with?
As others have already said, the next step to troubleshooting should be to try a different radio. That will rule out (or in) the power, feed-line, and antenna. I'd do that before spending any more time troubleshooting the radio.
If the radio is suspect, here are some questions I'd ask myself:
If not the antenna, feed-line, or power, perhaps the receiver circuitry is malfunctioning. Does the S-meter register any received signals?
Perhaps the internal speaker is blown, shorted, or otherwise malfunctioning. Have you tried an external speaker?
Rotate the volume and squelch knobs back and forth several times. Sometimes dust or corrosion can cause the potentiometers to malfunction and working them a bit will free the contaminant. Also check for "dead-spots", in that there could be one or more spots where the volume cuts out completely, even though it's not turned down at all.
Did the radio get wet? Was it operated outside of acceptable operating temperature? If you remove the cover, are there any fuses visible? Are any blown?
Good luck...
KK4HBW
With all due respect, and I'm hope I'm not speaking out of place (being new here and all), but I think this issue should be in its own thread, per the rules and announcements posted by the forum moderators. It would probably be a lot easier to follow along, too.
Bought it on ebay and it has supposedly been peaked and tuned
Might not be the cause, but that's a red flag right there. All legal issues aside, it's easy to screw up the receiver, knock something lose, or just generally make a mistake. The guys that do this sort of work are not exactly the sharpest tools in the shed.
Like we mentioned above, this all indicates a reason to try swapping out that radio with a known good working one to rule out an issue with your radio.
I'm not saying that it is the fault of the peak and tune, but that sort of modification tends to cast some shadows over things.
That also would have been welcome information closer to the beginning of all this.
drewdownkali
Silverdale Washington
Yeah, I am looking into getting a Uniden 880. Loves truck stop is selling them for 80 bucks!!! But they don't have any in and sale ends tomorrow. Hoping they get some in by tomorrow. Some kinda problem with their distributor.
