MPS Mercer County
rvrat1
Trenton nj
What I'm I doing wrong. SDS200 programed for MPS trunking NEXEDGE PER RR. scanner freqs verified in scanner. No Reception on MPS. Verified Data is correct on scanner. Also verified activity on SDR group 261. What am i missing?
PhillyFireFeed
The part where the only documented users of this system were kicked off several years ago and are now on the NJICS P25 system. You won't be able to hear anything on the system if there's nothing on it to hear. I don't know why the documented talkgroups haven't been marked as deprecated, but they should have been quite some time ago.
rvrat1
Trenton nj
Weird, Dont understand why talk groups are showing activity right now
Whiskey3JMC
Google-Foo Ninja 4 Hire
Simulcastylvania, TE
Someone always asks on threads like these: "You do have the NXDN paid upgrade, correct?"
Turn on the service types for the talkgroups you're looking to bring in ("tag' column in RRDB).
Fairly certain only police and fire made the migration to NJICS but I could be wrong. Assuming housing authority and city services are still on NXDN then the OP will need to turn on the Public Works service type.
tvengr
Well Known Member
Baltimore County, MD
Are the Channel ID's entered for each frequency?
PhillyFireFeed
They migrated as well. MPS literally kicked the entire city off the system for non-payment. Services are either on Mercer County or NJICS. I'm pretty sure its NJICS. I've seen some activity from them but didn't pay them much mind.
tvengr
Well Known Member
I see talkgroups for Trenton PD and Fire on NJICS, but no services. There are service talkgroups on the Mercer County trunked system:
Trenton​
DEC HEX Mode Alpha TagDescriptionTag
34815cDETrenton PDPoliceLaw Tac
34915dDTrenton FD SpOpsFire Special OpsFire-Tac
518206DTrenton FD 1Fire 1Fire Dispatch
520208DTrenton FD 2Fire 2Fire-Tac
52220aDTrenton FD 3Fire 3Fire-Tac
52420cDTrenton FD 4Fire 4Fire-Tac
52620eDTrenton FD 5Fire 5Fire-Tac
528210DTrenton FD 6Fire 6Fire-Tac
530212DTrenton FD TrainFire Training ChannelFire-Talk
536218DTrenton HealthHealth DepartmentPublic Works
544220DTrenton ParksTrenton Park RangersPublic Works
546222DTrenton PropertyPublic PropertyPublic Works
548224DTrenton PoolsPoolsPublic Works
550226DTrenton WasteSolid WastePublic Works
552228DTrenton SewerSewer DepartmentPublic Works
55422aDTrenton StreetsStreet DepartmentPublic Works
55622cDTrenton WaterWater Maintenance/Meter shopPublic Works
55822eDTrenton CityHallCity Hall SecuritySecurity
rvrat1
Trenton nj
Here's what I'm seeing on MPS this morning. There are active talk groups and show timed responses. None of these are showing active on the Mercer County Truck system. Yes, my SDS unit has NEXEDGE upgrade. I'm confused, anyone else want to give it a try? Thanks for all the responses so far.
Whiskey3JMC
As I stated in post #5 you'll need to turn on the applicable service types to hear traffic from those talkgroups on the SDS200, reference "tag" column in the database. TG-40 isn't ID'ed in the RRDB so you'll also have to turn on ID Search to pass traffic from Un-ID'ed talkgroups. If you can nail down TG-40's purpose, submit an update
Whiskey3JMC
No idea why you can't pick them up then. How many bars of signal are you getting from the control channel on the SDS200? Might be worth zipping up your Sentinel .hpe export and posting it as an attachment here so someone can have a look at your programming
rvrat1
Trenton nj
rssi -37 dbm. Search mode showing all TG. No audio though
GTR8000
NY/NJ Database Guy
BEE00
Did you import the system from the RRDB using software, or did you hand program it? Make sure the LCN's are correct for each site frequency, otherwise the scanner won't know what frequency to tune to for voice traffic.
rvrat1
Trenton nj
Programmed with Sentinel from RRDB.
