MPSCS Sites/Talkgroups 2025
knockoffham
Michigan, USA
Is something strange happening with MPSCS in Ingham? Or statewide? My scanner is silent today no matter what I set it to. I will experiment more when I am home from work. When I scan through the tower frequencies conventionally there’s still all sorts of stuff. Just wondering if maybe channel ID table changed or something?
nvanw27
WSDU482
Kingsley, MI
I have had no problems receiving from the River Central site today.
knockoffham
Michigan, USA
Never mind- I asked my dad and a couple friends who all have scanners I programmed the exact same. They’re working.
gusmacker74
Kalamazoo, MI
So I just got my SDS200 today and am starting to try and figure things out on the MPSCS system, I am in South Kalamazoo County and picking up St Joseph count and the system shows "Waters" or other sites. When i look those sites are far away.
I also think there is another site in Portage that doesn't appear to be listed.
hruskacha
Muskegon
MPSCS - Muskegon County Simulcast
Two new TGIDs heard, radio tests / joins only...
TGID 23770 with RIDs...
10614908
10614910
10613845
10615000
10614984
10615010
10614772
10615004
10614982
10614994
10614998
10614970
10614978
10614990
10614980
10615002
10615008
10614968
10615016
10614996
10614950
10614962
10614948
10614988
10614956
10615012
10614942
10615006
10614976
10614992
10615014
10614944
10613843
TGIS 23771 with RIDs
10615004
10613843
drdispatch
If 1000 hertz, think what 1 gig must feel like
Fightin' River, Michigan
Kalamazoo County uses a simulcast cell, so there are no stand-alone sites within the county.
Hit_Factor
Saint Joseph, MI
Browse through this page for MPSCS: https://www.radioreference.com/db/sid/100 to get familiar with sites in your area.
Read through this to learn about simulcast: Simulcast Distortion - The RadioReference Wiki
jimsokol
SW Michigan
If you loaded the whole MPSCS system, the Waters site and Kalamazoo County simulcast use some of the same freqs, so depending on which one your SDS stopped on is the name shown in the scanner display. If you want to know the real tower being displayed, after first enabling "detailed display mode" (see how at
), look at the RFSS ID and site ID. It should show "3" and "51" respectively when receiving Kalamazoo County simulcast, regardless of the site name being displayed because those items are taken right from the control channel being used.
Brettame5
BOLO on some radio RIDs..
I'm trying to find out the agency that any of the 92842XX RIDs belong to
knockoffham
Michigan, USA
That would probably be Grand Traverse (county 28) although I have found some radio IDs that do not follow the standard scheme around here in the capital area- some MMR ambulances and MSP radios
Edit: oops my bad didn't see you want a specific agency. Around here it is all over the place but I am working on a spreadsheet
Brettame5
ooooo would you mind sending a view link?
knockoffham
Michigan, USA
Still working on it. Currently Ingham county only because that’s where I live. A lot more work to go even for this county, since I am only usually doing scanning a couple hours a day at most. Most of it is “1033” radios.
