is the software for the mts2000 the same as the programing software for the mt2000?
Well, for starters the MTSX programming software isn't designed to work with MT1000 radios. You will never be able to program your MT1000s with it.Hello, new guy here. I have 2 MT1000 portables that I cannot program. I have a Panasonic Toughbook CF27 with Windows 95 and I believe a 266Mhz processor. The DOS software I am running is version R06.07.00 and it programs MTS2000 radios just fine! What am I doing wrong? Any help is greatly appreciated, thanks in advance--
Unknown what is going wrong with the MT2000s. They require the same RIB, cable and RSS software as the MTS2K and they both program the same way.
Are you certain the MT2000s you have aren't parts radios with HT1000 control boards, for example?
Are you able to describe exactly what happens when you attempt to program th MT2000s?
What indications (screen fail messages) are you getting, if any?
Are you even able to read the MT2000 when you have it connected?
