MTs2000 VHF
WLTEMT
Hey guys I just bought a MTS2000 flashport, i also bought a new shell with all the new knobs and stickies, my question is is this something that I could probably do myself or should I bring it to my local radio shop to have them do it....thanks WLTEMT
FFPM571
Nashvillle
Its not hard at all. Does the new plastic have the speaker and mic attached? IF SO Remove the antenna and knobs. Take the battery off and at the bottom of the case in the center gently pry the plastic with a small flat blade. Make sure not to get the rubber gasket. Then the gold flex cable that is on the front gently remove from the main chassis. To install do the reverse and make sure to be careful not to break the flex.
RKG
Boston, MA
One additional point: the new front probably has a speaker but most likely does NOT have the metal clip that secures the speaker to the front. This simply slides up and out of the old front and has to be transferred to the new front.
