MTS2000
ferryfan_ray
PNW
I believe you could use the FDB tool on the MTS2000 to add trunking to the flash code so long as the firmware in it is capable of trunking. I've used the tool on many MSC2000 mobile radios and added smartnet and smartzone trunking to radios that didn't have it.
And I have FDB, but I have no idea how to do that
Skypilot007
Medford, NJ
I'm taking a not so wild guess that you will be using your MTS2000 for non-affiliate scanning. If you can figure that out the FDB tool is much easier. Use your programming cable and see if you can read the radio with the FDB tool. If so start experimenting. You'll need to add smartnet trunking and/or smartzone trunking. Remember to save your original configuration before you start adding things. Only add what you need, don't go crazy adding options.
