MTS2000
ferryfan_ray
PNW
Hey, I got a MTS2000 today and for some reason, it does not do trunking. specs down below:
Model: H01UCH6PW1BN
S/N: 432AYG0839
FLASHCODE: 0000010000009
Easiest way is to just buy an MTS2000 that has the trunking flashcode. Seriously, they're cheap as dirt. I e-wasted a few hundred of them back in 2011 since the values are so low it wasn't even worth attempting to surplus them.
K4EET
Chaplain
Severn, Maryland, USA
Model: H01UCH6PW1BN
S/N: 432AYG0839
What would you possibly want to do with a MTS2000 trunking model? That is an antique nowadays and it also would make for a really poor scanner. If monitoring a trunking system is what you want to do, you really want a modern-day scanner like THESE (courtesy of Scanner Master Corporation)
Ant9270
The Green Weenie
Believe it or not, MTS2000 or XTS3000 are probably best for NASing a SmartZone system. If you overlook all of the specific details needed to even properly set up NAS, These at least have the option to "Affiliate on PTT"
K4EET
Chaplain
I was hoping that would not come up. I was trying to keep somebody out of hot water if they mess up on the programming and end up getting caught by the System Administrator and their team. Not fun...
Ant9270
The Green Weenie
Not condoning it, But just sayin'
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
That would be ok if you are listening to a type 2, 800MHz only, analogue only system.
Ant9270
The Green Weenie
Works fine on a Smartzone UHF system, with TX inhibit enabled. I’ve seen it done, but of course the hidden TG method always prevails.
mbnv992
Also known as MT2000 man on Batlabs since 2001+
AZ
On a side note - the OP’s flash can at least do mdc1200 encode and decode as well. A LOT of old mts radios I’ve seen for sale do not even do MDC, let alone trunking.
hill
Middle River, MD
Our local state transit agency had a UHF Smart Zone on T-Band frequencies.
kayn1n32008
Sector 001
:rolleyes: The model posted is 800MHz. Kinda hard to use a 800MHz radio to monitor a UHF system...
Ant9270
The Green Weenie
Obviously you can’t use an 800 to monitor a UHF system, but the NAS instructions for the MTS2000 are still the same across the board.
N4KVE
PALM BEACH, FLORIDA
NAS is not necessary for a MTS2000. Just set the enc switch for tx inhibit in both positions. Use as smart net. I monitored a few local systems for decades until they finally went Phase 2, encrypted. Never got “stung”. And the sys adm loves to sting radios.
Skypilot007
Medford, NJ
I believe you could use the FDB tool on the MTS2000 to add trunking to the flash code so long as the firmware in it is capable of trunking. I've used the tool on many MSC2000 mobile radios and added smartnet and smartzone trunking to radios that didn't have it.
ferryfan_ray
PNW
It is firmware 06.10
