mtx 8000
abrams
abrams
i have a mtx 8000 and every time i get it programed i get zapped how can it be fixed so it wont get zapped
C138NC
Tactical Taco Consumer
NC Taco Command
Your getting zapped?
Are you just putting in the RX frequencies or are you putting in both TX/RX?
You probably keyed up by accident and the dispatcher saw your ID come up and the system probably didnt recognize you then the communications admin zapped your radio.
So your radio is pretty much paper weight now if you accidently keyed up and they have record of your radio ID which would generally be the last 4 digits of the serial number.
Could that be what you have done? programmed in the rx/tx, thats illegal for you and probably a knock at your door by the police
If you cant do anything about the radio then might as well shelve it but next one you get, dont put in any TX frequencies or youll just get zapped.. again
zz0468
Banned
Zapped how, and by what?
I don't know whether to tell you to go to confession and cleanse your soul, or stay off the carpet with your tennis shoes.
Be a bit more clear as to what you mean.
w8jjr
Lincoln MI
Yes please define zapped. Is it on offical net with permission?
If you are trying to use it as a monitor on a system, program it with receive only option
C138NC
NC Taco Command
My conclusion is that hes programming the whole shindig into his MTX, whoever he keyed up to worked pretty quick to zap his radio and made it paper weight now, useless after being zapped, it acts like its dead and doesnt work, dunno if you can reprogram it to make it work again but i doubt it now. I thought i read somewhere the system admin would zap it by sending out a Ultra high freq but i dont have any source to back that up so i dunno if im right on how the system admin finds the radio and zap em.
All i know is the digital radios like the xts 3000 + and others are able to be deactivated by air and they wont work at all.
It was probably not an official net with permission for the way it sounds of being "zapped"
K8TEK
Banned
Ohio
You have no clue what you are talking about.
C138NC
NC Taco Command
Im just trying, i never got zapped.... but im right about the digital radios which are able to be deactivated by air if stolen or lost.
K8TEK
Banned
Ohio
You mean being inhibited over the air? Being inhibited over the air and "deactivated by air" are not even remotely close to being the same thing.
RIDs on Type II trunking systems are 6 digits, beginning with 7 and have nothing to do with the serial number of the radio. Not only that, the fact that he is generating traffic on a system he is unauthorized to be on is a crime. The OP doesn't need any help to get his radio working. If it was a legitimate authorized radio, it wouldn't keep getting inhibited.
Stop breaking the law and buy a scanner.
gatekeep
FAIL 01/93
New York, NY
Two things:
First, you can restore the MTX 8000 by shoving a uninhibited s-rec into it, usually.
Second, I don't recommend you program ANY radios onto a trunked system that your not an authorized user of, they will just continue to inhibit the radio over and over, it will be easier for you to buy a scanner.
K8TEK
Banned
Ohio
Two things:
Not necessary. The system administrator wouldn't have a clue his radio was on the system unless he generated traffic with it. The radio can be set to inhibit transmitting on all talkgroups and if you aren't using CPS to only affiliate on ptt. Of course he probably made his RID 700001 and keeps programming in the same one after it gets inhibited.
Just so you know, if the system admin wanted to do so, he could make your radio affiliate whenever he wanted and use the packets DF you.
talviar
Uniontown, PA
4 Models on the MTX8000's
all are Privacy Plus Versions
B3 which is a Type I only 16 channel radio
F3 which is a Type II only 16 channel radio
B5 which will do Type I, II, and IIi 6 button keypad 160 channel radio
B7 which will do Type I, II, and IIi full keypad 160 channel radio
Regardless of the fact it is Privacy Plus it can/will monitor Smartnet II systems without any issue as long as proper format talkgroup is in. ie if Monitoring Smartnet Type II talk groups would need F3, B5 or B7
As always YMMV and this is just my $1.95
Tony
WayneH
Forums Veteran
Super Moderator
Your master site
Folks, this is why we don't encourage or even permit talk of sharing RSS/CPS. You get people like this who should never even have access to the stuff. Think about that before you share with a complete stranger next time.
C138NC
NC Taco Command
pretty much, if you cant afford the software then save the money and get a scanner :D
Scanner, least expensive and more accessories at a fair price
Mobile/Portable radios, more expensive, more accessories as a sky rocketing price...
