Multiple 2-tone paging
Rheems1
Pennsylvania
Is there a way to set up different 2 tone paging alert based on zone? What I would like to do is set Zone 1 for our county and monitoring North Fire-ground channels and alert for my department only, I am good with that (after much trial and error) but I would like to make Zone 2 monitor south fire-ground channels (obviously with dispatch) and alert for 3 departments one of which is mine. Is there a way to set this up? I would think it would require 2 different two tone paging profiles but I have not dug in to see if you can create 2 separate paging protocols.
buddrousa
This is even posted in the Motorola Pager information.
1. Scanning and 2tone page tones are not a good idea.
2. Most Commercial Pagers can use up to 4 page codes on a Frequency.
3. I would only do this if the Dispatch Frequency is the same for all 3 Departments.
Short Paging Lesson 2 tone works on 2 things 1 TONE 2 Timing (Tone Length) any of the 3 are wrong Pager will not ALERT Scanning can cause you to miss 1/2 second of a tone and you miss the ALERT.
Rheems1
Pennsylvania
I should have mentioned it is all the same P25 Trunking system, I just want dispatch to alert on 2 more companies in Zone 2 but not Zone 1. I may have figured it out
buddrousa
2tone paging on a P25 Trunking System is not a PROJECT for a Do it Yourself. You are talking Life Safety that puts you 100% liable for Communication Alerts or lack of Alerts this should be done by a LICENSED TRAINED RADIO SHOP.
hruscher
in my g5 I have the entire countys two tone groups listed on the specific page and binding feature set to subgroup. then the assigned channels that you want the tones on, set with those subgroups attached. I have had no issue with the way mine works and will go from TG to TG alerting as necessary
Diesel0001
Northwest Ohio
I have a G5 and my county dispatches for multiple depts. How can I figure out tones for certain depts so I don't have to listen to all depts getting toned out?
hruscher
I personally used the two tone detect feature ion the unication firmware, it’ll log all of it for you
hruscher
if you have it turned on in programming, go to the channel you want to decode the tones on, then main menu > digital tone detect, turn that on, and then let that run until your tones go off again it will display on the screen, and you can see a history image.jpg
In this photo 3-4 are your tones
P2 is phase 2 - tone group 11 (the setting you use when programming it later) - and 593.75 is the exact tone it decoded
Diesel0001
Northwest Ohio
if you have it turned on in programming, go to the channel you want to decode the tones on, then main menu > digital tone detect, turn that on, and then let that run until your tones go off again it will display on the screen, and you can see a history View attachment 179804
P2 is phase 2 - tone group 11 (the setting you use when programming it later) - and 592.75 is the exact tone it decoded
I do all this through the scanner or pps?
hruscher
Turn it on in pps, just add it to the menu, everything else is done on the pager
Diesel0001
Northwest Ohio
So apparently I had to turn it on in the pps. A tone came over, but all it said was start of voice, end of voice
hruscher
did it give any numbers on your start of voice/end of voice?
It should decode it regardless
Rheems1
Pennsylvania
Alright I got this figured out with some help from a guy who programs these pagers, it is alerting for the 3 departments I want it to (over the P25 Phase 2 system). I forgot to ask him 1 question so maybe the group can answer this, I have a knob set up for just alerting over our dispatch channel which makes it function like the old minitor. It is programmed that the first knob setting is alert only and the second knob monitors the dispatch channel I looked at the work he did and wanted to reverse engineer for practice it but I don't see anything different settings wise between the alert only knob position and the monitor dispatch frequency knob. What am I missing?
