rbritton1201
Captain1201
- Joined
- Jul 27, 2020
- Messages
- 407
- Reaction score
- 81
I have three Discone antennas in the Attic (receive only), all in a row, separated by about 6 feet between each. I have a Comet Gp-1 VHF/UHF antenna connected to a transceiver (transmit and receive), separated by about 15 feet from the Discones, and positioned away by about 12' from a Television Antenna that's also in the attic.
I'm considering purchasing the DPD Productions Omni-X antenna to replace one of of the Discone antennas, which will be left in place, but disconnected. The Omni-X antenna will be installed away from all the other antennas, as far away as practicable. The Omni-X will be connected to a Uniden SDS200 scanner.
I've tried to position the antennas in the attic sufficiently away from each other so as not to induce an RF coupling effect. But, what is the recommended distance away from the other antennas so as not to induce RF coupling with the other antennas in the attic? I've always heard that 36" is adequate, but there must be a formula based on frequency that's more accurate, but I'm not sure what the formula is?
