Hey all,
I've got a Sony ICF-SW7600GR. I can receive a very strong and clear signal on 252 kHz. The station identified as WCVX 1160 AM. The tower seems to be roughly a mile away from my house.
From what I've read and google'd, looks like MW harmonics end up in the SW range. So I was wondering why I can hear it way down here in LW.
majoco has probably given you the correct answer here, it is probably an image issue in your radio, not a harmonic or actual signal from the transmitter.
Harmonics and spurs are sourced from the transmitting station.
A harmonic is some multiple of the transmitted frequency, for 1160 kHz you might find harmonics on 2320, 3480, 4640, 5800, etc kHz. All multiples of the 1160 kHz. A subharmonic is a possible signal that is at a frequency less than the fundamental freq, say one half the freq, but subharmonics are pretty uncommon in radio.
Spurs, or spurious emissions, are sourced from the transmitter also, but will not fall on multiples of the frequency. They are generally caused by either poor filtering in sub components of the transmitter or some undesired signals mixing in the transmitter. For example if the 1160 kHz TX has a solid state switched high Voltage supply switched at (just picking a number) 36 kHz and suffers poor HV filtering you might see the 1160 kHz signal and spurs on either or both sides offset at 36 kHz, for spurs possibly at 1124 kHz and 1196 kHz. If the fundamental is a SSB signal one of the two spurs might be inverted.
You can get image frequencies from inside your own radio via a couple different methods. You can also get images caused by external mixing of signals, not the fault of your radio or of the transmitting station, but some other external hardware that can grab two (or more) strong signals, mix them, and yield some odd results. For example I have seen poorly bonded fences near radio transmitters act as mixers and reradiate a new signal that is a mixture of the strongest fields present. I have also seen poor antenna connections at receive sites do the same thing.
T!
