Progress!
Got the cabinets rebuilt this weekend. Cabinet 1 has 12 Uniden scanners (7 BCT15's, 4 BCT15X's and a BCD996XT) as well as 2 8-port Stridsberg multicouplers and 2 13-port USB hubs.
Cabinet #2 has a PSR600, PSR410 and PRO197 as well as the 12VDC power supply, the NUC computer, a 13-port USB hub and a 7-port USB hub. It also has 2 RTL SDR's.
Both cabinets are on casters so I can wheel them around to get at the back. (wife's idea...) They will be placed under the desk and the lighting turned off on them while connected. This reduces the heat and visibility of them.
The only radios on the desk are the HP1, HP2, R8500, IC746Pro, CDM1250, the head for the TM731A, the BCD536HP and TRX-2.
The monitor, KB and mouse are ready to go.
The USB/Serial cables are scheduled to arrive tomorrow as well as a couple SMA-BNC cables I ordered. Once these arrive I will finish the links between the cabinets and the final antenna connections. I am using a singe 30 amp power supply to cover the 15 scanners, the Kenwood and the Motorola in the cabinets and the 3 multicouplers. The rest of the desktop units all have independent supplies.
Each of the 12 Uniden radios in the one cabinet have colors assigned to them. I used 6 different color wire ties for the antenna, serial and audio cables for the radios. One column has one tie each, the other 2. This way of one of the cables go bad I can replace it.
Tomorrow or Tuesday after the serial cables arrive I will start setting up the com ports one by one. After I get those going I will set up the sound cards. I will add the serial port and audio card names to the radio list I already have.
I will be running the scanners in the Uniden cabinet with ProScan. The GRE/RS ones will be with the appropriate ARX-xx product. In addition I have the 2 SDR's (UniTrunker) and the ANRB, so the computer will be busy...
I will post photos in the Photos forum when done!
