My unication g4 pager is frozen
hazrat8990
Wyoming
Do you remember which firmware you have? I just recently upgraded mine to V1.35, and still have the .zip file from Unication. You could email them and ask for a download link, or I can send it to you if you wish.
Honestly, I don't have a clue why you're having so much trouble. I've had my G5 since 2017, and it's been used & abused ever since. I've done several firmware updates over the years, and I've programmed it several hundred times without fail.
Cobra_Commander
InvisibleIndividual
Aurora,Ohio
Yeah i factory reset it it is working now unprogrammed.
The pager is doing the same thing that it did last 2 years I've sent. This is the third one that they've sent me in the mail now I gotta go spend 200 more dollars. It is stuck in scanning will not lock on to any towers at all.
Is this the same one you tried selling saying it was in excellent condition in the classifieds but saying it wasn't working in the forum? I think that was the end of last year wasn't it?
Where can i get the firmware at i googled it and can't find it.
Send Unication support an email with your model and serial number and within a week usually they will send you a link.
How does it work unprogrammed?
yeah it was on firmware 1.34
FW 1.34 worked fine for me, just updated to 1.35, but it wasn't because it was giving me issues. I did read in the forums that there were some issues with tones and paging, but nothing else serious with it.
Cobra_Commander
InvisibleIndividual
Aurora,Ohio
its working fine now i factory reset it and reprogammed the code plug and it works fine now.
N0GTG
Scanner programmer since 1997
Denver, Colorado
One of my G5's locked up -again- last night. It was in the drop-in charger, and when I got up, all the LED's were lit up. None of the controls worked, including trying to turn the unit off. As usual, the only solution was pull the battery. The lockup had drained the battery. I have to keep a small Phillips screwdriver with me in case this happens when I'm out. Unacceptable.
ryolsen8
BEE07
Have you sent it in to Unication?
North Prairie, Wi
North Prairie, Wi
This seems to sound like a programming issue. It may be in your best interest to find a g4 user and send them your programming to see what is wrong. These are designed for FIRE and EMS PAGING on a TRUNKING SYSTEM and they work very well for that 1 System 1 Talkgroup not a Hobby Receiver.
I know these are not made for hobby use, but that is exactly what I use my G4 for. It has performed flawlessly for 3-4 years now. I bought it used.
I use a drop in charger, because that mini USB port is fragile.
I just bought an SDS-200, and for my purposes, the G4 outperforms the SDS-200, hands down. I use the G4 for the Milwaukee/Waukesha county OASIS system, which has just about everything of interest to me on the system. It took a bit of learning to get it programmed to where it functions properly on the system, but now seems like a piece of cake.
