My XTS 5000R II is locked I need help!
Flashover071
rochester ny
Hello, I work at a hospital in the Public Safety Department, we just updated our radio fleet to digital and we didn't get enough radios for everyone to get their own. I bought a used Motorola XTS 5000R II so I could have my own and the radio is locked to where I can't delete or program a thing. Would anyone know how to either bypass or remove the (ASK) so I can program the radio. Thanks!!
prcguy
Contact the seller and return the radio for a refund.
KevinC
Encryption
I'm everywhere Focker!
Are you sure the XTS will do the "digital" mode your Public Safety Department switched to? Hospitals typically seem to use DMR as opposed to P25.
nokones
Sun City West, AZ
You will need to verify that the new system is P25 and if the system is conventional or Phase 1 trunk if you intend to use your newly acquired XTS5000R. Also, if the system is a trunk system you will need not only verify if the portable is flashed for Astro Digital voice, you will need to verify if the portable has all the Phase 1 trunking features. The portable is not compatible for a Phase 2 trunk system.
K2NEC
NA
In order to program with a software system key, the ASK would first need to be removed. If the OP knew how to remove the ASK, he wouldn't be asking here...
