Mystery antenna part
scan_madison
USA
I have in my possession a pair of U-shaped rods. I was told it is from some type of antenna. I am trying to see if I can make it some sort of antenna. Any tips from Antenna Gurus would be appreciated.
Dimensions are as follows:
Length of arm = 24"
Gap between arms = 2"
Thanks in advance.
Ubbe
Stockholm, Sweden
It seems to be cut for 120MHz
You can cut the lenghts to give a higher frequency and make a dipole.
Hammer the ends flat and drill new holes and fasten to whatever isolated material you have and connect the coax.
/Ubbe
jwt873
Woodlands, Manitoba
Your antenna pieces would look something like this when properly connected up....
In this case, it's the driven element of a Yagi antenna.
lmrtek
looks like a folded dipole from a vhf TV antenna.
Resonant around 180mhz
