N9JIG TriBay Completed.
N9JIG
Sheriff
Moderator
Far NW Valley
I ordered the new Tri-Bay rack about a month ago and it finally arrived today from AudioRax. Being that it is custom made it took a while but it is worth the wait.
I was pleasantly surprised to see that it arrived fully assembled, I had assumed it was going to require assembly. Being 5 feet wide the box was taller than my wife since it shipped upended. With no equipment installed it was not particularly heavy but it was a bit of work to remove it from the double box. It was very well protected and arrived undamaged.
I placed it on my wheel cart in the office. Since I already had all the equipment in the office waiting I only needed to collect a few tools and off I went. I soon ran into a minor snag, the threaded holes on the rails did not match the panels. There are two standards, I think I forgot to specify the one I needed and they sent the default one. I already had a tap for the rack screws so I grabbed the drill and drilled and tapped 8 new holes on both outside bays. The 746 panel fit right in.
I mounted the 746 in the center bay. I then mounted the 4 dual-radio panels. From the rear I installed the AC power strip, PowerPole RigRunner, USB hub and Stridsberg multicoupler.
I then ran all the interior wiring in the cabinet. Each of the scanners has an antenna jumper, power lead and serial port of course, there was also power leads for the 746 and 2 two-way radios.
After all that I moved the cabinet to the desk for final setup. The desk itself is on nylon sliders so I slid it out to connect the antenna leads and AC line cord. I placed the computer (Intel H.C. NUC) and monitor as well as the R8500 on top of the cabinet.
After testing the power leads I moved the desk to it’s place and set up the accessories (mics, computer i/o etc. After a good wipe down with a MF cloth I was done.
Since I had already set up all the racks and wiring harnesses last week it took me about 3 hours to do all the work, minus a half hour for dinner. I had not expected to even start it tonight but I already finished since I did not have to assemble the cabinet.
I already have one thing on my to-do list. The power supply that came with the 746’s rack has a loud fan. It seems to be on half the time so I think I will go to an Astron linear supply since there is no fan needed.
So here are the pics:
Here is the empty rack on the desk. I tried it to check the fit before I installed all the stuff. The radios and other stuff that is going into the rack is on the bookshelf to the left.
I installed the AC power strip on what will be the left rear. This puts the line cord on the correct side to the outlet.
Just about ready to flip the cabinet around to install the wiring.
From the rear of the right bay. This bay has the multicoupler (top) and RigRunner (bottom).
The left bay has the AC power strip, AirNav Radar Box and the power supply for the USB hub.
The wiring is just about done, ready to transition to the desk.
Here is the completed and operational setup. I am running ProScan for virtual control. Each 996XT is set to a difference screen color, matched by it’s computer partner.
A closer view of the completed setup. In addition to the 6 BCD996XT’s is a Kenwood UHF radio for GMRS and a TYT MD8600 for 2m & 440 FM and DMR. The R8500 sits on top of the cabinet.
Both radio cabinets in view.
The computer desk with the wall monitors used mostly for live-streaming rail and aviation cameras.
trentbob
W3BUX- Bucks County, PA
Absolutely stunning! Custom design, well planned and thought out.
Congratulations on one of the nicest shacks I've ever seen and I've seen plenty.
Great job!... Bob.
N9JIG
Sheriff
Moderator
Far NW Valley
As usual, FANTASTIC! Only question I have is "will this be your final version" ;-)
Doubtful for sure!
This morning I swapped out the power supplies. I disconnected the switching supply on the 746 rack and installed the PS125 that came with the 746. I then set up an Astron SRM-25 for the scanners and two-ways. I also found a flaky PowerPole jumper that I fixed and all is well with the world again.
JimD56
KO9JAD/Fire Lieutenant/Paramedic
Davie, FL (Miami/Fort Lauderdale Metro)
Rich,
I'm looking for a power supply as well. The Astron SRM-25 you speak of is the rack mount model. Did you mount it in the rear where you have the A/C power strip like in picture 2? Also, did you buy and install the side metal rails on the rear of the cabinet?
N9JIG
Sheriff
Moderator
Far NW Valley
Rich,
I did buy and install the rear rails. I was unsure how I would handle the power strip so I decided to get the rails and install them where the power strip was going to go.
As for the SRM-25, I removed it from the panel it came on and placed it on top of the cabinet for now. The cabinet is too shallow to allow it to be placed in rails at the rear without interfering with the radios.
ka1njl
Fairport, ,New York
Rich, you clearly set the standard. I fully appreciate neat and well organized radio rooms and yours are always both. The latest incarnation of your shack is beautiful.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
Well, somebody was a busy boy over the weekend! Looks nice!
03msc
RF is RF
The Natural State
Outstanding! I honestly was afraid I wasn't going to like it in comparison to the previous rack (which is irrelevant since it's your shack and not mine haha) but I think I like this a little more now that I see it. Always impressed by your ideas and execution of them.
iMONITOR
Silent Key
S.E. Michigan
Rich, did you have to hire "Two-Men & A Truck" to help you move that assembly?
N9JIG
Sheriff
Moderator
Far NW Valley
Years ago we used to tease our Records officer for his use of one of these carts around the office. When he retired and I took over that section along with other duties I realized that was the handiest thing around.
Fast forward a decade or two and a week after we moved into our new home I ordered this same cart. I use it for everything from bringing in groceries from the car to a painting platform.
For this job it was an easy way to work on both sides of the 5-foot wide cabinet before transferring it to the desk.
The empty cabinet was surprisingly light but with 9 radios and other stuffage inside it was pretty darn heavy to move.
