The NANO is GREAT !!..
I'd put the NANO up against the SDS100/200 and the Unication G4/5.. I actually have and for the money, the NANO holds its own.. The P25 P1 and 2 reception is as good if not better than either one of the aforementioned scanners.. Is it for everybody, Probably not.. It requires a LITTLE bit of common sense to put the WIO terminal and the NANO together.. You have to download three files, the zip code database, frequency database and WIO firmware
Once you do the downloads the fun begins.. For less than $250.00, you get a 150/450/700/800 MHz AM FM P25 scanner that could care less if the signal is LSM or plain C4FM..
I own 4 NANO's, a Micro and a P25RXII.. All work great on the Motorola 7/800 P1&P2 Systems and Harris P2 LSM system in my area..
www.bluetailtechnologies.com
