NCWRC frequency
ih784
Good morning,
I found the NC department of Environmental Natural Resources and the Wildlife Resources Commission frequency. There are four locations and none are close to me. Im not even sure im in the right spot. To my understanding the NCWRC is using VIPER. I’d like to monitor game wardens and the park service. Could someone point me in the right direction?
Whiskey3JMC
Surfer of the Delaware Valley Airwaves
Simulcastylvania, TE
Out-of-stater here so can't provide monitoring input. With that said, take a look at the Wildlife Resource & State Parks categories for applicable talkgroups listed in the RRDB in VIPER. Hope this helps. If you're looking for local input, reply back with your location and maybe someone can chime in with what may be monitorable for you & what site(s) to monitor
ih784
I’m brand new to this. I just bought an SDS100. It’s being delivered today and im trying load favorites lists and channels in them using sentinel. I’ll go through the link you posted. VIPER appears to be one big band? Or network ?I’ll figure it out 😂. Thank you!
VIPER is the statewide public safety system, most state agencies and many local and federal agencies (including USFS and USACE) also use the system. NCWRC uses the system a lot. It has hundreds of sites around the state with over 3000 talkgroups.
You will need to find the site or sites you are able to receive from your location, and program them in. The only traffic you will hear on a site is that which is affiliated to the site, this means that a radio is in the area and turned on, it is possible you will hear traffic temporarily from outside your area due to units passing through or visiting. I would urge you to read through the North Carolina VIPER sticky thread, it is packed with information on the system.
ih784
Sweet! Also thank you! I’ve got a LOT of learning to do. I found the WRC under state agencies but not Wildlife Resources Commission in VIPER.
ih784
If I were looking for an antenna specifically for scanning the NCWRC and the ncshp, what would I look at? A yagi? In what range? 800? 900mhz?
That depends where you live, but it should be in the 700 or 800 MHz range.
ih784
I wasn’t sure. I just kept seeing viper. I’m in Camden NC.
brian
DB Administrator
South Carolina
You're likely looking at the database from within Sentinel, which is logical. But you'll get more context of what you're looking at in Sentinel by looking at the RadioReference database on this site.
RRDB | North Carolina Scanner Frequencies and Radio Frequency Reference This is a link to the NC database page. From here you can review state level agencies and services, and also drill down into County level pages. That will give you more information about your specific county and counties near to you.
North Carolina VIPER Trunking System, Varies, Multi-State This is a link to the NC VIPER database page. The top section lists all of the transmission sites, and you can sort this by county and drill down into the sites specifically near you. The Sites and Frequencies table has a menu that you can see a map of all site locations, which can give you a great idea of which sites are closest to you. This map may only be available to premium subscribers. The second section is the talkgroup groups. You can browse through these for more detail. They're basically sorted alphabetically by county, and then state agency below those.
Also, each database page has a link to the RadioReference wiki. The wiki contains other helpful information like agency maps and lists that can be helpful with understanding monitoring in your area. For example, there's a link to an NCSHP Troop Map that can help determine which Troop and District your county is in.
Hope this helps.
This one is advertised as 7-800 but the specs say different. Will it still pickup?
@brian gives some good advice. I would add to it that you may be putting the cart before the horse, find the sites you want to monitor near you first, probably the one below, based on your location in the post above, then try it with a regular antenna first, if you are still having issues then look for a better antenna.
3 (3)060 (3C)South MillsCamden, NC851.075851.325851.800852.6375853.5625c853.675c853.750c
856.4375856.9375858.0625
ih784
Thank you both. I have a rubber duck 842 coming as well as a Tram 1410 discone and this one off of Amazon. I’m going to be using BNC connectors with RG8 cable. Not the best but it’s what I got. If one of the antennas don’t work, back to Amazon I goes lol. I’ll checkout the database and see what I get using the frequency and locations.
Directional Yagi Antenna Outdoor with SMA-Female Connector 7dBi 4G LTE Wideband 698-894Mhz Outdoor Antenna Universal for Cellphone Signal Booster/Cellular Repeater https://a.co/d/czwiRli
Thank you again!
ih784
One more question, I need to add the frequencies from the South Mills Location under VIPER in sentinel? Where does the frequency go? Under TGID or channel name? Or should it even be in viper?
tvengr
Well Known Member
Baltimore County, MD
There are a lot of Wildlife Resource Commission talkgroups on VIPER:
Wildlife Resource
DEC HEX Mode Alpha TagDescriptionTag
52087cb77DNCWRCAIR1Wildlife Resource Commission Air 1Law Tac
52088cb78DNCWRCAIR2Wildlife Resource Commission Air 2Law Tac
52089cb79DNCWRCAIR3Wildlife Resource Commission Air 3Law Tac
52090cb7aDNCWRCAIR4Wildlife Resource Commission Air 4Law Tac
52091cb7bDNCWRCCOM1Wildlife Resource Commission Common 1Law Talk
52092cb7cDNCWRCCOM2Wildlife Resource Commission Common 2Law Talk
52093cb7dDNCWRCDIST1Wildlife Resource Commission District 1Law Dispatch
52094cb7eDNCWRCDIST1CCWildlife Resource Commission District 1 CommonLaw Tac
52095cb7fDNCWRCDIST2Wildlife Resource Commission District 2Law Dispatch
52096cb80DNCWRCDIST2CCWildlife Resource Commission District 2 CommonLaw Tac
52097cb81DNCWRCDIST3Wildlife Resource Commission District 3Law Dispatch
52098cb82DNCWRCDIST3CCWildlife Resource Commission District 3 CommonLaw Tac
52099cb83DNCWRCDIST4Wildlife Resource Commission District 4Law Dispatch
52100cb84DNCWRCDIST4CCWildlife Resource Commission District 4 CommonLaw Tac
52101cb85DNCWRCDIST5Wildlife Resource Commission District 5Law Dispatch
52102cb86DNCWRCDIST5CCWildlife Resource Commission District 5 CommonLaw Tac
52103cb87DNCWRCDIST6Wildlife Resource Commission District 6Law Dispatch
52104cb88DNCWRCDIST6CCWildlife Resource Commission District 6 CommonLaw Tac
52105cb89DNCWRCDIST7Wildlife Resource Commission District 7Law Dispatch
52106cb8aDNCWRCDIST7CCWildlife Resource Commission District 7 CommonLaw Tac
52107cb8bDNCWRCDIST8Wildlife Resource Commission District 8Law Dispatch
52108cb8cDNCWRCDIST8CCWildlife Resource Commission District 8 CommonLaw Tac
52109cb8dDNCWRCDIST9Wildlife Resource Commission District 9Law Dispatch
52110cb8eDNCWRCDIST9CCWildlife Resource Commission District 9 CommonLaw Tac
52112cb90DNCWRCSWIDEWildlife Resources StatewideLaw Talk
52578cd62DWRCBURN1Wildlife Resource Commission Burn 1Law Tac
52579cd63DWRCBURN10Wildlife Resource Commission Burn 10Law Tac
52580cd64DWRCBURN2Wildlife Resource Commission Burn 2Law Tac
52581cd65DWRCBURN3Wildlife Resource Commission Burn 3Law Tac
52582cd66DWRCBURN4Wildlife Resource Commission Burn 4Law Tac
52583cd67DWRCBURN5Wildlife Resource Commission Burn 5Law Tac
52584cd68DWRCBURN6Wildlife Resource Commission Burn 6Law Tac
52585cd69DWRCBURN7Wildlife Resource Commission Burn 7Law Tac
52586cd6aDWRCBURN8Wildlife Resource Commission Burn 8Law Tac
52587cd6bDWRCBURN9Wildlife Resource Commission Burn 9Law Tac
52588cd6cDWRCMUTAIDWildlife Resource Commission Mutual AidLaw Tac
Frequencies go into the sites of a trunked system such as VIPER. If programming manually using Sentinel, you need to add a site to the VIPER trunked system and then enter the frequencies into the site.
ih784
Alright. I did that, changed the filter to wide normal and set the P25 to NAC 1F0. Should I worry about band plan or location?
tvengr
Well Known Member
The South Mills site does not show a Site NAC in the database. Where did you get 1F0? A P25 trunked system automatically loads the band plan from the control channel. You don't need to worry about that. If you are only using one site for now, set Location Control to Off.
ih784
Thank you. I did add the “Troop A” (covers my county) TGID to frequency. Thanks for telling me about the NAC setting.
tvengr
Well Known Member
If the wrong Site NAC is entered and the scanner is set to use Site NAC, the site will not be scanned. If you see a Site NAC flashing while you scan the site, that most likely the correct Site NAC and it has not been submitted to the database. If you do not have a GPS receiver for your scanner, location control will not do you much good. If you use a GPS, the latitude, longitude, and range values must be entered for each site.
akalynchs
NC (Piedmont)
If you’re in the South Mills area, recommend you put Pasqoutank and Currituck also in another location. The Pasquotank tower (ECity) is very busy plus it‘s affiliated with adjacent counties, the South Mills tower, not so much.
Good luck.
ih784
I’ll definitely check it out. I got some LMR-400 on the way.
