Lol, that's why I said,That’s dependent on the SDR hardware
Also depends how you look at it and how your scanning. An run of the mill sdr is close to 2.4 mhz minus a little for roll off while airspy mini will yield close to 4.5 mhz and the R2 and Duo sdr's will yield closer to 10 Mhz.depending on how far apart the freqs are
Sdrtrunk, 1 dongle, any dongle can be set up tune to each freqs within the bandwidth limitations of the dongle. One can add multiple dongles if needed.
Sdr# and DSDPLus FastLane with 1 dongle, regardless of bandwidth, can be set up to scan a list of freqs no matter how far apart they are as the dongle is scanning (tuning to) and not locked to a particular freq like in Sdrtrunk.
Sdr offer a great deal of flexibility One can set up airband freqs in FastLane or Sdr# and listen, or one with an R2 can scan the whole 225 to 400 mil-airband in a second and a half.
225-400 in 1.5 seconds. The best MilAir setup I've encountered yet.
This is the overall best setup for MilAir monitoring I've come up with yet. It's a TACO 225-400 antenna with 225-400 filter then Angle Linear low noise preamp. This feeds an Airspy operated by SDR Sharp with the Frequency Scanner plugin Сканер + поиск новых частот. by Vasili Beliakov. Each...
