Need help Hytera rd982S
Sgtgm
Connect the repeater to USB and see how it appears in the device manager. If there is a problem with the driver, you will see a yellow triangle icon.
Appears to be a driver issue.I have tried everyones suggestions so far and just about every combination of drivers software and windows version from windows 7 to 11.Am starting to think this older firmware needs a specific driver and software combination to work with these machines.Nothing is being recognized in windows to connect.I appreciate everyones help and suggestions obviously have not hit the right combination yet
a2s
Try using this driver for Windows 11. But first, remove the old version of the driver. In the installed programs, find Digital USB Driver and uninstall it.
APX8000
Sarcastic Member
AES-256 secured
Its a driver issue with the version CPS and firmware. When you install the firmware, make sure you delete previous drivers and then install the driver with the older CPS and firmware. I even found that I got up to Version 09 firmware it only worked with an older driver so you may have to select bypass driver install. This is the driver I have that works:
Digital USB Driver Software
V5.30.42.0
Sgtgm
V5.30.42.0
The firmware version on the plate on each repeater is V6.1.03.003 I haven't been able to access the repeater to read any of them.Thats where I have tried everyones suggestions but I am pretty sure I need an older combo of driver and software to work then I can do updates that work with new firmware and cps.I am starting to think I need an older computer to work with the proper older firmware driver combo.As best as I can figure this would have been 2013-14 vintage.I know nothing about hytera and the history with the motorola law suit but guessing that has something to do with all of this.I have some md652 mobiles that I got out of the same estate and I got the programming working with them and using the same cables I am trying to get to work on the repeaters.Been a nightmare!!
a2s
It's quite difficult to get an answer from you. Several people have already advised you to put the repeater into boot mode and check whether the repeater will continue to disconnect from USB. If not, then at least you can try updating the firmware to a more current version. Also, you haven't answered the question of how the repeater is displayed in the device manager. Take a screenshot of the device manager when the repeater is connected to USB.
Sgtgm
I have tried every suggestion given.The usb error comes up as usb not recognized.The repeater will not go into boot mode.These repeaters were all used in a dmr trunk mode judging by what I read from the mobiles I downloaded.The mobiles took updates as well as reading the cps and uploading so I know the cables work at least for them but for whatever reason I haven't found the right driver combination.I have programmed every level of motorola harris tait and Kenwood so I know how to make software and drivers work .Have never experienced this level of problems.As stated the repeater won't go into boot mode almost like it is locked out but again maybe a driver issue with the cables.These are after market cables and not original hytera.
Sgtgm
Can anyone suggest a good cable that they know works
Sgtgm
The only time it beeps is when the cable is put in the computer and the repeater.Power up the repeater get the usb beep but the computer never recognizes it and when the repeater starts to boot up you get the usb disconnect beep.Windows does not recognize it so definetly a driver usb issue
radioopperator
Repeater should be powered! And completly booted up before inserting programming cable!
APX8000
Sarcastic Member
AES-256 secured
Go buy a Hytera PC47 cable. Atlantic Radio has them in stock for $44.95.
Did you try the driver I recommended ?
Sgtgm
I had tried that driver several times I think the drivers good I will order a regular hytera cable as you suggest.
jasej
Hidalgo Texas
This drawing shows you how to build a programming cable for your Hytera repeater.
I hope it helps.
Regards
If you don't have access to a DB26 connector, you can use a DB15 connector and then cut off the right side of the shield so it can be connected to the back of your device.
As shown in the following drawing.
I did it this way because it was difficult to find a DB26 connector.
Regards.
To put it into firmware mode!
While the repeater is off...
Attach and use an SM16A1 microphone (the one that comes with the MD786 or similar)
Attach the microphone holder so that this action closes the ground circuit.
Press and hold the PTT button.
Connect or turn on the repeater.
Make sure the notification LED turns red and the repeater will be ready to receive the update.
All of this according to the service manual.
Regards
Sgtgm
Regards
Awesome thank you for sending the info
jasej
Hidalgo Texas
sure, friend
Regards
Regards.
Correction.......
This is for MD786G and RD986.
Not as shown in the top drawing.
Regards.
Muxlow
Super Secret
Middlesex County
I just came across this little option today iv never seen
Optional software license option
SW00156-Terminal Disable CPS read license for subscriber
My guess at this would be what your issue seems to be. Wont let you read the radio itself and would have to program it with a saved codeplug. Kind of a write only thing
Sgtgm
Kinda makes sense but you can't add a code plug if the cable doesn't work to program it.
Muxlow
Super Secret
Middlesex County
Im sure its a cable/driver problem as iv had that before. But just incase once you get a cable or build one for the rear port and it wont read youll know why. I think it will pop up some error msg saying something
See what happens once you get/build a cable :)
jasej
Hidalgo Texas
I'm not sure if that license exists in RD982, but I've seen it on HP series radios, such as the HP686-HP786.
The problem is problematic and easily resolved on HP series radios... locally.
"Radio reading not allowed." That's what it says when trying to read. On the H Series
Regards
