Need help programming trunking system with 330.
UnidenScanner
I have a uniden 330 I believe it is well I have that software and need someone who can help me set up a trunk system an easy way as long as I can pick up the frequencies, dont have to be fancy.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I'd suggest posting this in the state's forum where you live. You might get more replies, if no one answers here. And make sure you specify which software you have - the UASD (sounds like it) or ARC330. That way folks can send you pre-constructed files for your area. Be sure to say where you are (city/state/county will do nicely)
73s Mike
duckbird
Texas
Adding a new system to the BR330T UASD software System Data Base
1. Click on Data Base
2. Under System Data Base click New
3. Enter a System Name then select a System Type
4. Press Ok
5. Click on G
Enter a Group name or leave as default name
6. Press C
7. Enter a Channel name or leave blank
8. Enter a frequency
9. To add another frequency repeat steps 7 through 9
10. To add another Group repeat steps 5 through 9
11. When you finish, go to File and click Close
12. Click Save (Your new system is now in the System Data Base
Adding a Scanner Configuration name to the BR330T UASD software
2. Under Scanner Configuration click New
3. Enter a name (this can be anything you like)
4. Press Ok
5. Go to File and click Close
6. Click Save (you should now see the name in the Scanner Configuration area)
Adding information from the System Data Base to the Scanner Configuration
1. Double click on a Scanner Configuration name
2. Click on Systems
3. In the Data Base area highlight a System
4. Click on Add from Data Base
5. To add more systems repeat steps 3 and 4
6. Go to File and click Close
7. Click Save (all the systems you selected are now a part of the highlighted Configuration Name
Adding Scanner Configuration to your scanner
1. Make sure your scanner is connect to your PC
2. Click Write to Scanner
3. If you don?t want info that is currently in the scanner erased, uncheck "Erase Memory Before Writing" Also make sure On Air Programming is unchecked
4. Click on Write then Click on Ok
