UnidenScanner said:
I have a uniden 330 I believe it is well I have that software and need someone who can help me set up a trunk system an easy way as long as I can pick up the frequencies, dont have to be fancy.
Adding a new system to the BR330T UASD software System Data Base
1. Click on Data Base
2. Under System Data Base click New
3. Enter a System Name then select a System Type
4. Press Ok
5. Click on G
Enter a Group name or leave as default name
6. Press C
7. Enter a Channel name or leave blank
8. Enter a frequency
9. To add another frequency repeat steps 7 through 9
10. To add another Group repeat steps 5 through 9
11. When you finish, go to File and click Close
12. Click Save (Your new system is now in the System Data Base
Adding a Scanner Configuration name to the BR330T UASD software
2. Under Scanner Configuration click New
3. Enter a name (this can be anything you like)
4. Press Ok
5. Go to File and click Close
6. Click Save (you should now see the name in the Scanner Configuration area)
Adding information from the System Data Base to the Scanner Configuration
1. Double click on a Scanner Configuration name
2. Click on Systems
3. In the Data Base area highlight a System
4. Click on Add from Data Base
5. To add more systems repeat steps 3 and 4
6. Go to File and click Close
7. Click Save (all the systems you selected are now a part of the highlighted Configuration Name
Adding Scanner Configuration to your scanner
1. Make sure your scanner is connect to your PC
2. Click Write to Scanner
3. If you don?t want info that is currently in the scanner erased, uncheck "Erase Memory Before Writing" Also make sure On Air Programming is unchecked
4. Click on Write then Click on Ok
