Need help understanding
lamoilleweatherman
JEFFERSONVILLE
Can anyone tell me does anyone hear swanton border patrol I have been looking and looking for the frequency and I can’t find it I do have a Whistler pocket scanner that is hook too a outside antanna and is a p25 scanner can anyone help me if anyone knows thank you Rodney
wtp
Port Charlotte FL
from google,
The Swanton Sector of the U.S. Border Patrol in Vermont utilizes several radio frequencies, including 162.8250, 162.8500, 162.9000, 162.9250, 163.1500, 163.6250, 163.6750, 163.7250, 163.7500, 163.7750, 165.8750, 165.9250, 168.8500, 168.9750, 170.6250, and 170.6875
they are from a 2008 post on radioreference. so i wish you luck.
ecps92
Taxachusetts
Your best bet is to search the 162-174 band at 12.5 khz channel spacings.
IT could be your location, however they do tend to mix ENC and CLR, so depending on your radio it maybe ignoring the ENC
LathamScan
Latham, New York
I can confirm that the 163.150 MHz. P-25 repeater replaced the former 163.625 MHz. analog repeater on St. Albans Hill.
The BIG issue is that almost ALL of CBP's comms are encrypted (I'm guessing at the AES 256 bit level), so monitoring is virtually impossible. All of my previous trips back to the Islands, trying to monitor the CBP, have been unsuccessful due to encryption.
ecps92
Taxachusetts
I don't have any notes for 6250 ever being at St Albans, it's been 1500 for C-01 since the Analog Days when it was 156.7
6250 with $368 was always part of the NH (E-xx) zone from Cannon
BP up that way is broken down as
E-xx East for NH/VT
C-xx Central for VT
B-xx for NY/VT
W-xx for NY
Periodically it has been heard (usually Dispatch) in the CLEAR
Hopefully the OP returns (not back since the post) and reports what he may have found in SEARCH
In the past few years we've also discovered that ICE/HSI built out an entire NH/VT Vote-Scan net
sadly if on a hill, some of the NAC's are the same as the BP over in Maine :)
