CbDxer
Hello, I just purchased this scanner and after doing all the Sentinel Database & Firmware updates I downloaded it into the scanner. For some reason I am not receiving the Nevada Highway Patrol & EOC.
I am not sure if the database never included it or not? When I stream this feed online it's constantly active. Yet on my scanner I get nothing. I have an outside scanner antenna on the roof so reception isn't the issue. I get all the other broadcasts just fine.
The whole point of purchasing this scanner was to listen to this group. If anyone in the Las Vegas area could give me some step by step programming for this model scanner I would appreciate it.
Another thing I noticed is when it loads the database it also starts scanning California & Arizona frequencies with the Nevada ones. Yet I set the range at 50 miles. I tried hitting permanent avoid on some of these but being there are hundreds of these it is taking forever.
Then I don't know if I run an update on the database in a month if it will erase all the avoids I put in.
Is there a specific brand of micro sd cards this model prefers? Just in case I ever wanted to upgrade to a 16gb.As far as using a new card do I just format the new one and plug it in, then load the database from the Sentinel sofware.
I love this scanner but talk about complex.
Thanks for your help!
